We have an orifice assembly as in attached image.
Can anybody help us make this as a Custom OPM_component, with Isometric symboloy
Any help is much appreciated
Hello Peter,
Thankyou for posting your query on Bentley Technical Forum. We will investigate about your requirement and will be updating you. Would you be able to send the graphics (dgn) so that we can try create a component out of it.
Harshavardhan K
Product Engineer I, Facilities Engineering
Hi Peter,
Could you please try this wiki article and select orifice flange as custom component before that you need to add a custom attribute "USE CLASS AS CUSTOM COMPONENT" to orifice flange
