Hi All,
When you open the raceway router, the first thing to select is the system.In which XML file do I have to change which variable to rename for example the "cable tray"?
Thank you in advanceRegards
Philipp
Hello Philipp,It is not recommended to change the name of raceway systems from XML file.It can lead to errors in the dataset.Can you let us know your requirement to rename the 'cable tray' ?Looking forward for your update.Regards,Lalitesh Vaidyar
Addition: We just want to change simply the name from "Cable Basket" to "Mesh Wire Cable Tray". Not the variable itself, that is not a problem right?
