Hi
As shown in the figure below, it is a 100*80*50 reducing Lateral T
As shown in the ISO drawing below, the size in Reports does not show the size of the branch
As shown in the figure below, it is the definition of size in report.def. Ask the teacher how to define the size in report.def so that the size displayed in the ISO drawing reports is 100X80X50?
Hi Dongjin qu, Thanks for posting your query to Plant forum.
Open the report.def file in the notepad++ as per your required workset. For the opening of report.def file, Please use below mention path. C:\ProgramData\Bentley\OpenPlant CONNECT Edition\Configuration\Workspaces\NEW_Test\WorkSets\Test\Standards\OpenPlant\Isometrics\styles\IFC\config In this report file , define COLUMN=7:R:SIZE3 and save all the changed setting as shown below Launch OpenPlant isometrics manager and click on the style icon as shown below. From the style icon select the iso style as per your requirement and click on the seed file In the seed file(Template) add the size3 column as shown below After that save all the change and generate isometric for the PIPE_LATERAL_TEE_REDUCING_ONE_RUN_AND_BRANCH.
Thanks, Aishwarya Kulkarni
Answer Verified By: dongjin qu
