Hello all,
I have used to split one pipeline to 2 sheets by using the isometric breakpoint. I will not use any other method to split isos at the moment. For some reason OPM CE Update 8 will not calculate correctly the number of the sheets. I used that information in the drawing title to mark the correct sheet.
iso sheet 1:
iso sheet 2:
The sheet numbering in the drawings should be 1 / 2 in sheet 1 and 2 / 2 in sheet 2. This configuration has worked in OPM V8i and this problem was noticed during migrating to OPM Connect Edition.
BR
Tuomas
Hello toumas,Thank you for posting on Bentley Plant Forum.This is not an issue OOTB. Could you please raise a Service Request on this concern, this needs to be investigated and taken up internally.Regards | Soham Mhaskar.
Hello Soham,
Ok I made an SR regarding this issue
Hello Tuomas,
Was this issue solved? I am having the same issue in my project, in the OOB it works but not in our build, the same issue you were facing.
Please, let me know.
Alina
