If there an easy way in OPIM V8i to turn have existing fittings excluded from Partid's?
Managed to get everything else excluded.
I should also say EXISTING over EXISTING NO ISO.
Hope you're not using "Demolished" for other purpose in your build:
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/19169/how-to-define-existing-lines-in-openplant-isometrics-manager
Thanks Tuan and Sean.Sean! Let me also check in the meanwhile.
Regards | Soham Mhaskar.
No mate.
Thanks Soham.
