Has anyone attempted to export an OPPID model to AutoDesk Plant 3D P&ID?
From the research I've done, it seems the graphics come across, but the specs are different. That's all I've been able to find.
Any info or experience on this would be helpful.
We are using OPPID but our client is using AutoDesk Plant 3D.
Gary
Hi, We are facing a similar issue. Is there an update on this topic ?
Hi Lema,Sorry for last response.Well we are in discussion about this part with our Dev and will be updating you at the earliest.RegardsAshutosh Patil
Hi, any update on this? We are facing a similar task.
Currently using:
OpenPlant Modeler - Version: 10.09.00.74
[MicroStation - Version: 10.14.02.01]
Hi Ashutosh. We are having the same request/issue. Please answer this question with an update as soon as any information is available.
Thanks.
