Hi All,
We changed the units to Millimeters because that's our standard work format.
However, on the BoQ document we want it to appear in Meters, is there a simple way to just divide the calculated amount by 1'000?
Thank you in advance& Regards
Philipp
Hello Philipp,You need to edit the report template for the BOQ report.You can refer to the below Wikilink for the detailed steps.
