Is there a way you can lock out the ability to have insulation on for flanges and valves?
Hello Sean,
Let me just check that for you mate.
Regards | Soham Mhaskar
Thanks mate.
Just out of curiosity, What's the driver to having insulation locked out for these components?
Some fittings aren't insulated, but can still be modelled as such and come out in the iso's. IF I turn off all fittings in the OPIM settings, then even elbows don't display insulation. Not what I want. Back to old habits I suppose, lock out what I can't trust users to do manually.
Hi Bear,
In OPIM you can turn on/off the insulation on individual components using overrides
# ShowTracing: Influence display of tracing# EXAMPLE: ShowTracing = 1 enable display of tracing# ShowTracing = 0 disable display of tracing## ShowInsulation: Influence display of insulation# EXAMPLE: ShowInsulation = 1 enable display of insulation# ShowInsulation = 0 disable display of insulation
Frank
