Description of valve, excluding actuator. When the material list is published, it is merged into three,In fact, I need valves in the material table that represent three different actuators.
It seem to add the condition of actuator in the selection,How to set?
Thanks for your help
Hi ZHomg Wang,
I guess what you mean is that the three valves currently get the same BOM or PART ID and are thus grouped in a single BOM entry. If you want three different entries you will need to change IE_DESCRIPT or the valve item code. Both are set through the supplemental isometrics/isoextractor schema.
In the below example I added a redefinition of IE_DESCRIPT. (in the FLUID_REGULATOR class) It basically adds the operator class name to the the description. Because IE_DESCRIPT is now different for the three valves, each valve will get a different part ID
You might need to make a few changes to your report definition but this is the basic workflow.
Frank
Answer Verified By: zhong wang
