Hello all,
I'm using OPM U9 and for some reason the weld for tap connection is shown in the isometrics. I noticed that in the OPM the component state for the weld is design but in the OPIM it reads IE_EXISTING = 1 which means that the component state is somehow modified to existing? How can I get tap connection weld in the isos?
BR
Tuomas
Hi Tuomas,Thankyou for posting your query on Bentley Technical Forum.Let us check this scenario at our end and will be updating you asap.RegardsAshutosh Patil
Could you clarify what was the resolution to this problem? I'm having the same issue.
BR, Teemu
Hi Ashutosh,
Could you share the resolution to this problem with the tap connection welds, thank you.
Hi Teemu,Could you please check the schemas part wrt Isometric schemas components state as shown in below link. Mainly the expression IIf(IM.Match(this.STATE,"EXISTING", "FOR_DEMOLITION",""),1,0)https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/55195/how-to-generate-correct-isometric-of-pipeline-if-the-component-state-is-different
Thank you for the reply! I managed to solve this problem with selecting Tap connetion -> Modify component -> Component state -> Applying "Design" (I dont know why, but in tap connections the Component state is automatically empty).
