I have a client who wants a different format for spoolid that he wants on the iso's.
The format goes:
MK-$(unit)-$(lineidentifier)-$(isoshtnum)-$(SPOOLID)
Unit comes out fine, but how to I get lineidentifier, from line number, to come out as well as a custom field used for the iso sheet number I set up called isoshtnum?
Hi Bear,
This spool label is a user label so you can use any isometrics property available on the component. Just see if you can make it work that way
Regards, Frank
Thanks Frank, that's what I wanted.
