I have a client whose seed files uses units of resolution set to 100 instead of 1000. I've fixed the text and dimension issues, but is there a way to adjust annotation cell scale for things like note etc.?
Rahul Kumar
Rahul, as the heading says I'm still in V8i.
Just want to know, other than resizing the cells, is there a method in the overrides.txt file to scale annotation cells like note_tp, note etc.
Any more feedback on this Rahul?
Hi Bear,
There is no easy option for make this work, It is more or less expected that the seedifle and cell libraries have the same uor per masterunit. The override scale option is only working for component cells, not for annotation cells
Frank
