I do not want the pipe support number to display in ISO drawing and in report,
However, I did not select the support tag labels in user labels and annotation(#) the suport in report / rep_sortgroups,it does not work
How to hide this number.
Hi Yichen,
There are multiple ways to get what you want.
Using rep_sortgroups.txt: add skip = 1 to the supports group
SORTGROUP = SUPPORTS RULE = IE_TYPE=CT_SUPPORT SKIP = 1
Using overrides:
RULE=IE_TYPE=CT_SUPPORT NOTONBOM = 1
Both solution will prevent a part ID to be generated for the supports. You can still report on these items. In most cases the items without a part id will not be shown on the BOM. If they are still there you can filter them out using something like INCLUDE=PARTID>0
Frank
Answer Verified By: Yichen Gong
Nice , it's working,thanks a lot,Frank !
