1) What is difference between open-plant & auto-plant specification
2) How specification are work in Background
3) Can i used open-plant specification in Auto-plant
Hello Adinath,
The OpenPlant Specs can't directly be used for AutoPlant. The Column structure is a bit different and the AutoPlant Class has AT_ at each class column.You will need to convert the Spec using OP Spec Gen and then utilize the specs. Follow below Wiki for your reference.
Thank U sir for Quick Reply,
I Have Olet Spec in Open plant, i want to transfer this spec to auto-plant spec.
