Hello All,
For example, we can use imperial spec under metric workspace, 3 in the spec mdb while 80 in OPM. I'd like to know how could I get the metric 80 as per 3 in the spec mdb regardless spec and workspace. Thanks.
Hi Changsong,Thankyou for posting your query on Bentley Technical forum,Could you please explain about this part,"how could I get the metric 80 as per 3 in the spec mdb regardless spec and workspace.regardless spec and workspace"in more detail.RegardsAshutosh Patil
Hello Ashutosh,
For example, use IM unit in mdb and use it under metric workspace, the Main_size is 3 in mdb, but it will show 80 in OPM. OPM converts 3 in to 80. I'd like to know if I can get 80 from 3 by OPM SDK. Thanks.
Changsong,the size would reflect what we have inserted in spec →Pipe table→Main_size field.But with SDK part I really dont know. well need to check.
