Hi
As shown in the figure below
When catalog performs the repair SYSID, the following prompt indicates success, but when the catalog.mdb file is opened, the SYSID column is empty, that is, the repair tool is invalid. How to solve it?
After clicking "renew", open the catalog.mdb file, and the SYSID column has value
Thanks for posting query to Bentley Plant forum. SYSID repair will work when we have some value in SYSID column catalog. You need to add different value for felids(for example a,b,c,d.e). This will not work with blank fields.
As shown in the figure below, the SYSID gives the value of the example and then performs "repair", but the corresponding SYSID is not generated, and the values in it are still a and b.
The tool "repair" cannot generate SYSID, which seems to be a problem only with up9. The previous version did not have this problem.
Hi Thanks for the update , we know this issue in update9 so that we have logged defect for this issue. It has been fixed in update 10. If have any other concern then please log a service request.
Answer Verified By: dongjin qu
Thank you for your help
