is it possible to automate the OpenPlant PSDS Migrate tool (Upgrade and Convert)?
For example, can I use Batch Process to migrate a set of DGN files? Does this require some user interaction?
What about logs? There's no column with the DGN file name for example...
Any ideas?
Thanks in advance
Hello IronMonkeyThanks for posting your query to Bentley Plant forumWhat is the prime requirement for this conversion process? Do you want to convert PSDS model to OpenPlant Modeler V8i then OpenPlant Modeler CONNECT?
Regarding automation, I believe it is possible to automate this process. However if a model file conversion has any sort of error then it wont convert and we need to inspect that separately.
ThanksRegards | Deepak Singh
Hi, thanks for your reply.
You are right, the requirement is to convert PSDS models to OPM CE, through OPM V8i SS6 migration process.
1) should I use a batch process with key-in? Is there anything better (I heard something about ProjectWise Automation if it is applicable)
2) can I get better logs? The only log file I see is in %LocalAppData%\Bentley\Logs
Here you can find some rows of OpenplantModeler.log. As you can see there's no column with file name. Is there something I can change in configuration to get better info?
2021-08-03 16:41:57,734 DEBUG OpenPlantModeler.PSDSMigrate - The mapping schema maps PSDS Property of PIPE_PIPE to OP3D Property PLANT_AREA [Area] of PIPE, but does not exist in the PSDS Instance.2021-08-03 16:41:57,734 DEBUG OpenPlantModeler.PSDSMigrate - The mapping schema maps PSDS Property of PIPE_PIPE to OP3D Property CREATE_TIMESTAMP [Created Timestamp] of PIPE, but does not exist in the PSDS Instance.2021-08-03 16:41:57,734 DEBUG OpenPlantModeler.PSDSMigrate - The mapping schema maps PSDS Property of PIPE_PIPE to OP3D Property NOMINAL_SIZE [Nominal Size] of PIPE, but does not exist in the PSDS Instance.2021-08-03 16:41:57,734 DEBUG OpenPlantModeler.PSDSMigrate - The mapping schema maps PSDS Property of PIPE_PIPE to OP3D Property COMPONENT_NAME [Component Name] of PIPE, but does not exist in the PSDS Instance.2021-08-03 16:41:57,734 DEBUG OpenPlantModeler.PSDSMigrate - The mapping schema maps PSDS Property of PIPE_PIPE to OP3D Property STATE [Component State] of PIPE, but does not exist in the PSDS Instance.2021-08-03 16:41:57,734 DEBUG OpenPlantModeler.PSDSMigrate - The mapping schema maps PSDS Property of PIPE_PIPE to OP3D Property LENGTH_EFFECTIVE [Length Effective] of PIPE, but does not exist in the PSDS Instance.
