Hello
Is there a command to refresh the tags on a P&ID to basically run the Parser Regular Expression? I have made a change in the schema for the Name of a tag for all the objects in a P&ID and want to refresh them all in one shot. At the moment, the only way to initiate the Parser Regular Expression to run is by making a change to the Number of the tag.
In the above example, I want the first digit of number to move to the Train field. It will parse when I change the number from 0002 to any other number:
I want to avoid doing this to prevent any mistakes when changing the number to initiate the parser so is there a Key-In that can do this?
Justin
Hi Jfelix,
Thankyou for posting your query on Bentley Plant Technical Forum.
Kindly take the backup of dgn and then try the keyin like Pid component refresh properties or Pid annotation update all.
Ashutosh Patil
Thanks for the quick reply Ashutosh.
I don't have the option to run the Pid component refresh properties or Pid annotation update all commands as they are unknown key-ins after trying to execute it. The pid annotation redraw all is available but doesn't trigger the parsing:
Are there any other commands?
