Is there a way to force OPM to assign a spool number to a lap flange? I can add them post placement, but that's just time consuming.
Hello BearThanks for posting query to Bentley Plant forum. Spool number assignment consider the end type as per value defined in config variable. Please refer below wiki article
Answer Verified By: Bear
Using STUB_END that worked a treat Deepak.
Many thanks.
