Hi,We have already modeled, Plant via Autoplant, some customized attributes that need to add Piping, Equipment, Instruments. Is there any possibility to add the attributes in Datamanager tools so many lot components are here
Hello Rajesh,
You can add custom attribute for piping table by following below wiki link steps:
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/36020/how-to-add-additional-field-to-component-data-in-access-and-sql-and-to-make-it-an-editable-data-field-in-piping
To add new attribute in equipment follow below wiki link steps:
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/34778/how-to-add-custom-fields-in-equipment-database-record
Once custom field get added values can be add via Datamanager or in Database.
Hope this helps. Looking forward to your reply.
Abhijit Bute
