Ask the teacher
Software OPM, version: up9
As shown in the following figure, the model outside the clip volume scope box should not be displayed, but it is displayed in up9. Please ask the teacher where the problem occurred?
Hi Dongjin qu,
Thanks for posting your query to Bentley Plant forum.
To make it working correctly, please try below steps.
1. Go to folder where you can find Modeler.cfg.
2. Open Modeler.cfg in notepad and search for section
"Including View Functionalities"
3. Comment (add # mark ) all the variables of this section from MS_DRAWINGMODELSEED to MS_DGNLIBLIST_DRAWINGSEEDS.
4. Save all the changes, load OpenPlant Modeler and check the result again by applying clip volume.
HTH
Regards | Deepak Singh
Answer Verified By: dongjin qu
Hi Deepak Singh
Thank you for your help
Hello Dongjin quGreat! that provided suggestion helped here to move forward on this concern.We would request you to please raise service request so that we can have proper record for this issue and it can be fixed in default setup of OpenPlant Modeler. To raise service request, please refer below link
