Hi all,
can I use a VBA macro (or key ins) to execute a query (or open a .ecquery.xml file) in OpenPlant Modeler CE?
I tried to record a macro, but with no results...
For example, I need to create a batch to execute a query on a list of DGN files and save results...
[SOLVED]
I solved the problem by myself... I didn't check the SDK Example:
QueryPipeWithPortsExample
I can use C#.
Hi Ironmonkey,Apologies for reverting late late on your query. But thanks for letting us know the outcome as well.RegardsAshutosh Patil
can you share how you figured it out? I'm trying to do something similar
