Is there a Wiki or page that lists all commends available for overrides.txt?
Things like NotOnBom=1 etc.
Hi Sean,
That is a good question.
We do have one existing link which we have posted times back - but then many things added down the line.
How to: User Overrides for Isometric components Applies To Product(s): OpenPlant Isometrics Manager Version(s): 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) Environment: Windows 7/8.1/10 (64 bit) Area: Settings/Attributes… Last edited over 4 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki 1 comment
We will update this link and keep you posted, so that you can use in future. Meanwhile I will share the list of fixes for as per latest CE version so that you can take reference to.
HTH,
Rahul Kumar
Thanks for that Rahul.
Would you know if there is an ability to not show one of the size values based on something like below in overrides.txt.
#RULE: Remove SIZE from report for REINFORCEMENT classRULE
INCLUDE = IE_TYPE=CT_RPAD#INCLUDE = EC_CLASS=REINFORCEMENT
@@SIZE1=0Color = 7
The colour change comes out fine, but I'd like to tunr off size1 for this set of project iso's.
Any more info on above thanks Rahul?
I have sent one list of new fixes for your quick reference.
However on such new addition we are in process to have it documented at one place for quick reference to all users.
Once its done we will share it with you.
