Parser Regular Expression
 I have a tag in Data Manager that has a tag that is something like this 1440-AC-999D07 where:
Area = 1440
Equipment Code/Device Code = AC
Number = 999
Suffx = D07
I have tried multiple variations of Parser Expressions and when I browse for the tag from Data Manager the number part of the suffix gets truncated.
^(?<PLANT_AREA>[?\w]*)-(?<DEVICE_TYPE_CODE>[?\w]*)-(?<NUMBER>[\d{3}])(?<SUFFIX>.*)
^(?<PLANT_AREA>[?\w]*)-(?<DEVICE_TYPE_CODE>[?\w]*)-(?<NUMBER>[\d][\d][\d])(?<SUFFIX>[?\w]*)
^(?<PLANT_AREA>[?\w]*)-(?<DEVICE_TYPE_CODE>[?\w]*)-(?<NUMBER>[\d][\d][\d])(?<SUFFIX>[A-Z0-9]*)
^(?<PLANT_AREA>[?\w]*)-(?<DEVICE_TYPE_CODE>[?\w]*)-(?<NUMBER>[\d][\d][\d])(?<SUFFIX>[?\S]*)
What should the proper parser expression be where OPPID will not cut out the number portion of the suffix?
Justin
