OPPA schema configuration
Hey people,
Inside Project Administrator there is schema editor, an "easy" tool to make changes inside schemas of workset.
I've wanted to change all unit dimensions to our prefered ones, also added needed information tabs. Flow rate - m3/h, pressure - bar (barg), volume - L etc..
For equipment I've changed inside unit schema with Class Editor. But for valves and instruments i've tried Schema Editor (much more item types to change)
Strangely enough it worked for equipment (Class Editor), but for all "Piping and Instrument Component" part it didn't worked (Schema editor).
Maby someone has already had the same problem?
Is there a normal wiki for how to use/change schemas or it's every time a tryout solution (change then check)?
P.S. "OpenPlant Project Administrator allows users to automate the simple configuration and project setup tasks thereby ensuring that the user is not needlessly exposed to a developer’s tool for schema management when making simple changes that are done at the beginning of every project"
I believe units are simple change and needed for every project..
OpenPlant Project Administrator CNNECT edition 10.7.0.32
OpenPlant Modeler CONNECT edition 10.7.0.32
