Hi there,
We met a problem during the process of generting pipe based on pipline number created in OPPID. As you can see in the following pic, after referencing the imodel which published from OPPID, some pipeline number are shown correctly in OPM, but some only show PipingNetworkSystem. Does anyone has clue how to solve this problem?
Hi Shu Zhang,
Thankyou for posting your query on Bentley Plant Technical forum.
I thing that pipeline ecexpression is failing hence it shows failure value.
Is it working in OPPID, the line which shows pipingnetworksystm.
Ashutosh Paatil
All the pipeline number showed correctly in OPPID. We have tested to publish the same OPPID file through the OOTB environment, and everything works right from OPPID to OPM. So, we don't think it is related to pipeline number expression. However, it doesn't worked correctly in our customized environment. So, we are wondering is there anywhere else control the expression in OPM?
Hello Shu Zhang,
Thanks for Posting the reply in Bentley Technical Forum.
Can you please log a service ticket for the same issue so that we can have a detailed investigation of your workspace data?
You can refer the attached wiki link for the same
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/38551/how-to-log-or-report-service-request-for-bentley-plant-products
Shubham Sawant
