My Update Sequences settings do not save-write when checked-in(Update Sequences from Within References dialog Properties) anyone else experiencing this kind of issue? You create a drawing which is a Titleblock with 3D model as reference. In order for text to show ON TOP of some of the 3D you need the 3D Model First in the sequence, then the Titleblock/text. This is easily accomplished in the references/Update sequence dialog. But when you Write the file and re-open it, the sequence is wrong and the text will be hidden BEHIND the 3D Geometry again until you change the update sequence AGAIN.(It is not saving this setting)
Any Ideas?
Hi Paul,
Thanka for posting your query on Bentley Technical Forum.
Let us check this scenario at our end and will be updating you at the earliest.
Is it possible to share 2-3 images wrt the sequence is wrong and the text will be hidden BEHIND the 3D Geometry again until you change it.
Ashutosh Patil
Correct sequence on Left, After Check-IN, re-open and you get the Photo right, sequence was not saved, text not visible, behind 3D Reference.
