My Update Sequences settings do not save-write when checked-in(Update Sequences from Within References dialog Properties) anyone else experiencing this kind of issue? You create a drawing which is a Titleblock with 3D model as reference. In order for text to show ON TOP of some of the 3D you need the 3D Model First in the sequence, then the Titleblock/text. This is easily accomplished in the references/Update sequence dialog. But when you Write the file and re-open it, the sequence is wrong and the text will be hidden BEHIND the 3D Geometry again until you change the update sequence AGAIN.(It is not saving this setting)
Any Ideas?
Hi Paul,
Thanks for posting your query on Plant Forum.
Can you share about which product you mentioned here? Is it OpenPlant Modeler?
Also share the file for testing.
Rahul Kumar
