I am Facing Problem to generate the secondary supports showing the Primary Interconnection.
Sample Output snap is attached, Can we generate the Supports in Attached Format???
Hi Prashant,Thankyou for posting your query on Bentley Technical Forum.Let me divert your query to AutoPlant Team.RegardsAshutosh Patil
Hi Sir,
Thank you for your help. Looking ahead for the solution. If the Query is resolved then it will save our Drafting time which we are loosing now.
Prashant Barse
Hello Prashant,
This is special type of support, by default AutoPLANT have base support available, Special support can designed in AutoPLANT with the help of Bentley Prostructure,
or can be customized by programming in AutoPLANT.
Hope this helps.
Regards,Abhijit Bute
Hello Abhijeet,
As you Specified we generally model the Secondary supports in Pro-Structure & Generate the Drawings. Afterwards comes the Drafting part to Marks the Line Numbers & Primary Support Tag like Guide or Anchor & Dimensioning for the same.
If there are no's of line on single support then we have to make View box then use Flattener then Pest it on the Drawing which is exported in Pro Structure. This is Time Consuming activity. Some of our Clients require Details as Mentioned.
The solution you have suggested is not Feasible for the N No's of supports i think its also time consuming activity to customized by programming in AutoPLANT.
Hope I Have Explained the Requirement & Problem we are Facing.
