We currently migrated from OPM SS6 to OPM CE Update 9, and thus migrated the workspace as well, and updated schema from OpenPlant_3d.01.07.ecschema.xml to OpenPlant_3d.01.08.ecschema.xml. There are certain properties that were open for edit in SS6, that has been greyed out in OPM CE Update 9, and cannot edit them. The highlighted property is greyed out on OPM and we cannot edit its value anymore.
We also used Bentley Class Editor to detect the issue and the property is false as readonly, but still its greyed out in OPM.
<ECClass typeName="NAMED_ITEM" displayLabel="Named Item" isDomainClass="False"> <BaseClass>PLANT_BASE_OBJECT</BaseClass> <ECProperty propertyName="IsTagReserved" typeName="boolean" description="Indicates whether tag has been reserved" displayLabel="Is Tag Reserved"> <ECCustomAttributes> <HideProperty xmlns="EditorCustomAttributes.01.03"> <If2D>True</If2D> <If3D>True</If3D> </HideProperty> </ECCustomAttributes> </ECProperty> <ECProperty propertyName="NAME" typeName="string" description="name of item" displayLabel="Name" /> <ECProperty propertyName="DESCRIPTION" typeName="string" description="description of unit." displayLabel="Description"> <ECCustomAttributes> <ISO15926MetaData xmlns="Bentley_Standard_CustomAttributes.01.02"> <DefinitionBackReference>rdl.rdlfacade.org/data <EntityType>dm.rdlfacade.org/data <IdPCA>RDS4037656140</IdPCA> <Designation>DESCRIPTION</Designation> <CreationDate>633083904000000000</CreationDate> <Creator>tchr</Creator> <Status>Incomplete</Status> </ISO15926MetaData> </ECCustomAttributes> </ECProperty> <ECProperty propertyName="ALIAS" typeName="string" description="alias of unit name." displayLabel="Alias" /> <ECProperty propertyName="INSULATION_FUNCTION" typeName="string" description="Primary Insulation Function" displayLabel="Primary Insulation Function" /> <ECProperty propertyName="MODULE" typeName="string" description="Module" displayLabel="Module" /> <!-- temp comment out for TP1 ECProperty propertyName="ACTIVE" typeName="boolean" description="Current item is active" displayLabel="Active Item" /--> </ECClass>
Varsha
Hi Varsha,Thankyou for posting your query on Plant Technical Forum.Could you confirm how did you migrated OPM SS6 to OPM CE Update 9.Also could you share the screen shot of the greyed out property.RegardsAshutosh Patil
We followed the below link to migrate the workspace
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/50505/how-to-upgrade-openplant-modeler-v8i-workspace-to-openplant-modeler-connect-edition
Below you can see Project and Station ID associations have the greyed out "Name" property, and we want this enabled.
The same property in Bentley Class Editor
I would request you to kindly raise the Service request.Also could you confirm if you have verified this name property wrt OpenPlant schema?l
Hello Ashutosh, Thanks for your help, we appreciate!
I created new workspace for CE from SS.
1. used v8i upgrade from OPM PrjAdministrator.
2. Schema Upgrade tool from OPM CE Prj Administrator.
3. The above pasted image is showing report that certain old schema cant be upgraded.
Can you please help on this?
Kedar Bhokarkar
In OpenPlant_3d schema, go to Station_ID class→Name Property.Override the name property and then change the custom attribute location to Supplemental modelling and make it editable instead of Readable which would help you to enter the values in stad preferences.Thanks & RegardsAshutosh Patil
