While trying to open a specification via the OP "Specification Generator", I get the following error message:
I have tried to open other Spec from other projects and also get the same error.
I am using OpenPlant Spec Generator Connect Edition Version 10.08.00.51
I was able to open the spec only a few days ago.
Any help would be appreciated.
Cheers, Philippe.
This issue has happened again today after windows updates to office applications.
However instead the error was "*.MDB is not a valid catalog". uninstall and re-install of access engine has fixed it.
Aishwarya, your version 16.0.4519.1000 is out of date and should be re-installed with the latest version
Thanks for posting query to Bentley Plant forum. This issue is known to us and it happing because of windows update KB5002099. If we remove this update then it will work fine. https://support.microsoft.com/en-us/topic/description-of-the-security-update-for-office-2016-december-14-2021-kb5002099-10670400-427f-4819-8de6-abd11e73100b
We found the February release was stable (KB5002138) and resolved the issues.However there was a recent March release that supersedes breaks it again. (KB5002160)
