Hi, while using Open Plant Connect Edition Update 8 - Version 10.08.00.51, I try to produce Isometric drawings on an A1 sheet (Client supplied).
The default windows extent is quite small relative to the sheet size so I enlarged it.
However, once I go over a certain size (still too small to my liking), all the associated text move to the same location (outside the window extent btw) and the iso becomes impossible to read (ref picture below)
I looked around but couldn't find any clue on how to fix this issue.
Any help would be appreciated.
Cheers.
Philippe Sene.
Thanks for posting query to Bentley Plant forum. Can you please raise the Service request for this issue?
Can you please give me your iso styles folder so we will check this issue at our end.
Thanks Aishwarya,
I have now raised a Service Request.
I have a few Iso styles, do you want me to send the content of all iso styles folders? How shall I send them?
Let me know.
{SrvReqNo:[7001356213]}
Hello Phillippe,
May following wiki link steps help you.
Hope this helps, Looking forward to your reply.
Abhijit Bute
Hi Abhijit,
I have followed the above recommendations but still have the same issue.
Thanks for your help however, I'm still waiting to hear back from Aishwarya.
Cheers, Philippe.
