I noticed the 3D Connexion keyboard pro is compatible with Microstation but not with BRCM.
Is this functionality planned for the future?
Hello Philipp,
Yes it is compatible with MicroStation and you can use it with BRCM as well.But, you will face some issues with speed while using the fly/walk features inside BRCM, these issues are already logged as bugs and the fix will be there in the upcoming BRCM CE Update 10.
Please let us know if you need more information on this.
Answer Verified By: Aadarsh Tale
I currently use the 3D Connection puck for navigation and it works alright with BRCM but has been left out of Navigator CE.
Good to hear that you can work with it without any issues and will be able to use it with enhanced performance in coming BRCM CE Update 10.
