When I used OpenPlant Isometrics Manager CONNECT Edition Update 9 to generate ISO drawing, I enlarged the drawing sheet to A1. However, the auto-generated Bill of Materials get messy. The content not align with the header of the list. Could you tell me how to deal with this problem? Thanks very much.
Thanks for posting your query on Bentley Plant forum!
This can be managed by setting correct length in report.def file. In earlier version the spaces were designated using characters, but now we have provision to measure the distance in 'mm' in seed file and then assign it to report.def.
In simpler term increase the length offered in report.def file and try.
From latest v8i version onwards many features are also added to simplify BOM content. You may refer below wiki article Configuring the BOM and Reports Applies To Product(s): OpenPlant Isometrics Manager Version(s): 08.11.11.XXX (SS6) Environment: Windows 7/8.1/10 (64 bit) Area: Settings/Attributes Subarea: -… Last edited over 5 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
read section 'OpenPlant Isometrics Manager V8i (SELECTseries6) Version: 08.11.11.224 Refresh 2' mentioned in wiki referred above.
HTH,
Rahul Kumar
Hello,Thankyou for posting on Bentley Communitites,Could you please check in reports.def file for the location of value from path C:\ProgramData\Bentley\OpenPlant CONNECT Edition\Configuration\WorkSpaces\OpenPlantExample\WorkSets\Metric\Standards\OpenPlant\Isometrics\styles\IFC\config.Also could you let us know workflow to enlarged Sheet to A1.
