Since we use the raceway with a 3m standard length.
For example, if the total length is 10m, then their will 3 pieces 3m and 1 piece 1m raceway.
Then How can I set the ID for each of them?
Hello LongJun,
Thanks for posting your query to Bentley Communities.For your query,Are you directly routing all raceway segments or using place part and place straight option?
Hi Kale,
We just directly routing all raceway.
Do you have more guideline for this?
Hello LongJun,You can use the Raceway ID tool to assign to raceway segments.You can select single or multiple raceway segments and assign raceway IDs to them.You can refer to the below Wikilink for details-
Hi Vaidyar,
This has been solved.
It needs to change the .XML first, then the cable ladder/tray will build as 3m standard length and for thses smaller than 3m will be variable.
