Hello
Just wondering if imodels that are generated from OPM can process features in a slab that was modeled in application. The slab is currently modeled in OPM and not OBD as a temporary solution but when the imodel is generated the features have a FAILED value in the Feature Status field when checked in the imodel. Are these objects/feature not compatible with imodels generated from Openplant Modeler?
Justin
Hi Justin,
So when you generate an iModel the 3D slabs are not in the iModel or they have an value of FAILED in the elements status field?
Ray
Hi Ray,
The slabs are in the model with a FAILED in the elements status field and they do not have the cutouts as shown in the first screenshot. The first screenshot shows how it was modeled in OPM but it appears as one solid piece in the iModel.
I would get Bentley to have a better look at why the solid is not being saved in the iModel correctly.
Check the Message Center in OPM when you create the iModel and see if there is a meaningful error, missing plugin or something,
