I'm revisiting this again as our list is growing.
I have specs created in a different workset that I have copied into a new one. I have the workset in PA, but when I try to open the spec through Spec Gen I get the above error.
I have checked the path is correct in Preferences:
When I try and open the spec I still get this error.
Is there something else I should be doing.
Curious why this is such an issue vs V8i?? We usually keep a master set of specs and cats that are edited in place and updated in the projects as required.
I would like to get back to that is I can get over this hurdle.
Thanks for posting query to Bentley Plant forum. Did you add your previous catalog in new workspace ? Please active the current workspace path from OPPA.
It has been added to the preference file, yes.
I have checked in OOBT and it is working fine. Are you using a network drive?
Yes I am.
It's been a week, any feedback on this at all?
I have checked with using network drive and it is working fine at my end. Can you please create an SR for this issue so we can investigate using your workspace?
Aish, I'll go over a few things on the weekend and log a call on Monday if I can't fix the issue.
