I've come into a situation where we have the same line number across multiple files. Can I run the from each file at the same to to get the correct iso numbering?
If you run each file separately you get the same iso name, which don't work.
You're welcome.
Thanks Sean to post here.
However we shall also create wiki article for same and make it available for all users.
Rahul Kumar
I appreciate that Rahul, but I also believe that threads should be closed out if possible. I know how frustrating it can be finding a thread on the same issue I have and not being able to find a resolution.
