I am developing a C# Addin for OpenPlant Modeler Connect Edition that reads data from the specification db (.mdb, Microsoft Access).
How OpenPlant connect to Microsoft Access Database (.mdb), for example the specification database?
Is there any API we can use inside a C# AddIn to read data from a .mdb file?
C# AddIn requires 64bit version of Microsoft Access Drivers, but users PCs are using 32bit Office and they do not have administrative privileges…
Another problem we found is that the installation of 64bit drivers on a machine with 32bit drivers requires registry changes
This is explained in this article, for example:
How to install 64-bit Microsoft Access database engine alongside 32-bit Microsoft Office | AutoCAD | Autodesk Knowledge Network
Is there a way to avoid it?
Thanks for posting query to Bentley Plant forum. I will discuss this internally and Update you
Hi. Any news?
