As per the image above, our specs have been updated to have the bolt_dia change to the Mxx number.
Problem I have now is that this field is now blank in the iso bom.
Is there anything I need to do to have the bolt dia. come through as noted?
Schema has been update to have BOLT_DIA as string instead of double.
Hi Bear,
OPIM automatically determines whether a bolt diameter is metric/imperial or that a bolt length is metric/imperial. For that the properties BOLT_LENGTH and BOLT_DIAMETER are used and these are expected to be a number. You can add the 'M' to the bolt size in the report using an 'if' expression. If you use the alphanumeric format in another context you could also use the pre/post processing facility in OPIM (hook.ini) to remove the 'M' part form BOLT_DIAMETER
Regards, Frank
Thanks Frank, that's what I thought.
