Hi Everybody,
I have an issue with the line jumper setting.
Normal Pipelines (Major, Minor,....) does not break up, when they are crossing each other. I have tried different settings. The PID_Jumper class is set to different priorities for each line type. The overall variable "SCHEMATICS_JUMPER_SAME_CLASS_HORIZONTAL_PRIORITY = 1" is also set up.
The Line "breaks" works for instrument lines. But not for pipelines.
Please see the result in OPPID (last Update 10)
Any idea, what the reason could be?
Hi MartinThanks for posting your query to Bentley Plant forum. Can you please check the settings mentioned in provided wiki article? We have checked this in one of CONNECT version and it is working. In an ideal case, it should be the same for V8i SS10. Please check and let us know the outcome of it.
Hi Deepak,
please see my settings:
So it still not working. Self intersection of pipelines and instrument line will not break up.
Hi MartinThanks for the update.In which version you have tried above mentioned settings? It looks like something missing. Can you please raise SR for this concern as the settings looks correct to me based on provided snapshots.Thank youRegards | Deepak Singh
it is the latest available Update. I have started the workset from default. So it should be easy for you to validate if you have the same issue.
Hi MartinThanks for the version details.I have checked this one in mentioned version and I can see the same concern of not breaking the line.This looks to be some bug in the product. However, we are looking if any possible customization to make this working.ThanksRegards | Deepak Singh
