We've started getting an error with our non-admin users when they try to create an iso.
An Exception Error comes up with:
Path cannot be the empty string or all whitespace
Anyone come across this before and where it would likely be. I gather it's a permissions issue, but can't see where it might be an issue??
Thanks Sean to Clarify,
This mostly encountered upon using upgrade workspace or previous version style folder being replaced. Is anything similar with the case?
Rahul Kumar
Rahul,
this is just Notepad being a pain.
I normally don't use it as I have Notepad++ on my machines, but new firm and I'm still setting things up.
I must admit, I haven't had this much of an issue with Notepad for some time. This is the third time since I've been here that this has happened. I just need to get back into good habits and not use Notepad.
