OpenPlant PID Connect 9.1
Is there a configuration variable to disable component gallery from displaying? We want users to only use our customized ribbon.
Hello Neil,
Thanks for posting your question, we are investigate and update you soon.
Regards,Abhijit Bute
Hello Neil,Kindly Check the wiki article on How to Disable Component Gallery in OPM CELink: communities.bentley.com/.../how-to-disable-component-gallery-in-opm-ce
thank you Abhijit. I need to disable in OPID not OPM. That variable does not exist in pid.cfg so I added it and it seems to work.
