Hi
How do I redraw raceway components when I have done for example a name change in class editor and want to apply levels/colors to already existing components?With pipelines I would have done this
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/9866/to-trick-openplant-modeler-by-refreshing-properties-to-redraw-pipelines-by-inheriting-new-changes
What's the method for doing the same for raceway components?
Hello Johan,You can use the same key-in mentioned in the Wiki Article- ' bmech rebuild ' to rebuild the tray components.For tray components you need to select the Raceways tab and then input the key-in bmech rebuild. It will redraw the tray components with the set levels/colors.After running the key-in, rebuild of components is completed info message will be displayed in the message center.Also, if you need to manage the component symbology for cable trays you can refer to the below Wikilink-
Answer Verified By: Lalitesh Vaidyar
Super!Weird that it does not show in keyin dialog
Hi JohanThis key-in is a hidden key-in and it should not be used all the time. It is strongly recommended to use this key-in on a backup model file to avoid any data/work loss.
Answer Verified By: Deepak Singh
