Does anyone know how to create a Mechanical Olet (refer icon on attached image) in OpenPlant? I am trying to implement it in the HDPE spec that I've created.
Sam
forgot the attachment
Hello Sammy,Mechanical Olet is available in Victaulic Spec in the default Metric WorkSet.Since, you have created custom HDPE spec, you need to customize the schemas for adding the Mechanical Olet.You can refer to the below Wikilink-
Answer Verified By: Lalitesh Vaidyar
Hello Lalitesh,
Thanks for your reply. I'm after the encircled one on the snapshot though. Do you happen to know if there's an existing EC_CLASS_NAME for that one?
Thanks in advance for any help.
hi again,
ignore my reply, found it in the victaulic spec that you've mentioned.
Thanks heaps mate.
