I want to do some minor updates of the exsting equipment with some information on OPM. Normally, I will drop the equipment to cell and do all the necessary updates and then convert back to equipment and put back the information. But for the equipment with a lot of information inside, I don't want to drop and input all information again. Is there any other way to do this?
Thank you
Thiha
Hi KyawIn addition to this request, another easiest approach is to Update the existing component graphics. In this workflow, all the properties will be remain entacted and you should be able to update the graphics of custom equipment.Steps as:
Please check both the suggested answer based on ease or complexity of custom equipment.HTHRegards | Deepak Singh
Answer Verified By: Deepak Singh
Hi Deepak,
Thanks for your quick response and advice.
1. First method "customization for enabling data storage in ecmodel file" - I tried this following the linked instruction. I stuck at locate missing reference BentleyBase.01.00. I located and clicked "Open" but the button is inactive. Please refer to attached screenshot.
2. Right click drop - This helps. Thanks a lot.
Kindly advise 1 as I want to explore that option too.
Hi KyawThanks for the meeting.In the meeting we have explained the workflow that need to follow to achieve your requirement.Regards | Deepak Singh
Answer Verified By: Kyaw Thiha
