Is there a way to set the Level Naming by Pipeline Name and Pipeline Symbology by Service in OPM? Can someone help me with the expression combination.
I would like to have levels according to Pipeline Name (I've done this) but with Pipeline Symbology (Colours) according to Service (couldn't get it to work together)
I have set the Level Naming by Pipeline Name but whenever I follow the Wiki on Pipeline Symbology by Service, my Level Naming by Pipeline Name gets broken.
Is this combination possible? Thanks in advance.
Hi SammyThanks for posting query to Bentley Plant forum.Please refer below wiki article that should help to move forward.
I've tried this but couldn't get the colours to work. It is taking the colour of the newly created level (pipeline name) which is 0 (white)
SERVICE REQUEST SNAPSHOT
Hi SammyThanks for raising the SR, we have communicated the solution over email. We have checked the same and with updated Named Expression we are able to see the desired result.Thank youRegards | Deepak Singh
hi Deepak,
I've tried this but it didn't work. It doesn't seem to read the template from the OPModeler dgnlib file. It works on the OPModeler dgnlib file when I create a pipeline there but when I create a new model it doesn't work. It means it's not reading the template.
Hi Sammy Thanks for the live meeting In the meeting we have noticed that you have upgraded your schema from lower to latest version of OpenPlant Modeler CE Update 10. There are new variable introduced into Modeler.cfg file that is required to fetch the OPModeler.dgnlib content into a model file.
We have added that variable to Modeler.cfg and able to get the desired result. Variable name is as MS_DGNLIBLIST_DRAWINGSEEDS < $(OPENPLANT_WORKSET_STANDARDS)/Modeler/Dgnlibs/*.dgnlib You can also refer below wiki link
Answer Verified By: Sammy Sabile
Thank you very much for conducting the online meeting and solving the issue!
