I am trying to incorporate historical Autoplant files into autocad drawings only to be greeted with half a dozen messages about missing object enablers.
the following are missing:
AT_Reboids.
AT_Cust. arx app for AT_cylinder entity, AT_Cust. arx app for AT_box entity, AT_Cust. arx app for AT_cone entity, AT_Cust. arx app for AT_torus entity, AT_Cust. arx app for AT_dome entity,
This is the same issue I encountered some 15+years ago and it was like pulling teeth trying to get the relevant object enablers to allow autoplant objects to show correctly in Autocad.
Can someone in Bentley please explain why the same issue is still a problem now and supply me with the relevant enabler or link to it as a matter of urgency.
Hello Ric,
You can go through the new WIKI article for AutoPLANT Object Enablers for AutoCAD from here:
Also, you will find the active download links for the Object Enablers in this article to test at your end.
