hello,
has anyone experienced this issue?
I've created a custom component (valve) but when I am placing it using the place from cell and placing it in a space, it doesn't seem possible to orient the valve vertically.
Is there a technique to follow in defining the origin and connect points in order for this vertical orientation to work?
Thanks in advance.
Hi Sammy,Thanks for posting query to Bentley Plant forum. We will check this internally and update you accordingly.Regards | Neha Chougule
Hi Neha, kindly let me know if you've found a solution.
Thanks.
As far as I know you can't. I always rotate it manually. For an example I have made cell library for our team from wich we use pipe supports, and it connects to the pipe always horizontaly. My advice would be just rotate the item manualy
hi, thanks for your input. yes, that's what we are currently doing.
