I activated active depth once and it's annoying. how do I cancel it. everything is displaced compared to where I click.
Thank you
Although a little dated, but should give you an understanding about how to work with active depth:
https://communities.bentley.com/products/microstation/f/microstation-forum/132189/how-to-i-reset-or-remove-the-display-set-depth-active-depth
Hope it helps.
